Author Topic: Testing huge photo in signature file  (Read 5813 times)
« on: August 24, 2008, 05:18:12 PM »
Let's see if this works....
blah-blah-blah
next thing below will be my sig file....
Re: Testing huge photo in signature file
« Reply #1 on: August 24, 2008, 05:19:03 PM »
Ugh. We don't want that....
« Reply #2 on: August 24, 2008, 05:43:28 PM »
I don't see a way to prevent people from putting images in their sig file. Options are, basically:
1) Eliminate all use of BBC code across the forum (you can't just do this to sig files). If we do this, then no way to make bold text, italics, and all the other formatting. Every message will look the same.
2) Make the maximum sig file size so small (maybe 10-20 characters) that it would be nearly impossible for someone to use an image in their sig file.
« Reply #3 on: August 24, 2008, 05:46:36 PM »
If we do #2, the shortest possible sig file to post an image would be like this:
That's 22 characters. So with a 20-character max sig file, we'd be okay. But you can't do much with 20 characters....users might not be too happy.
Wonder if we can turn signatures off altogether....
« Reply #4 on: August 24, 2008, 06:02:09 PM »
ACK! I TURNED BBC CODE OFF ALTOGETHER, AND NOW YOU CAN'T EVEN USE THE QUOTE FEATURE. THAT WON'T WORK...
Offline alex.found.pete.the.chop
  • ... in hell with a bottle of milk
« Reply #5 on: October 15, 2008, 06:30:14 PM »
The Signature field only allows one character?
« Reply #6 on: October 15, 2008, 10:04:11 PM »
Yes. Please read the Sticky post at the top of this board called "Photos in sig file solved".
